Reference / Stems
S&M Shredneck
S&M Bikes
2015–2018
https://www.sandmbikes.com/product/hardgoods/shredneck/
S&M Shredneck Stem
  • Intended for street, park, dirt/trails, etc. - strong enough for any BMX discipline
  • First available on 11/23/2015 - initially only available in black and raw
  • The latest incarnation of the Redneck stem - has a shorter reach, slightly less drop, and a simplified, clean look
  • A more refined "Redneck" if you will
  • Made on Haas automation mills
  • Recessed compression bore for a cleaner look
  • Internal machining to keep the weight down
  • Material: 6061-T6 aluminum, CNC machined
  • Weight: 11 oz. (312 g)
  • Style: frontload
  • Engraving: engraved S&M logo on the faceplate and side of the stem
  • Compression bolt area: recessed to give a flush clean look
  • Colors: black, raw, blood red, purple, camo
  • Reach: 50mm
  • Rise: 7mm (upright), 24.75mm (inverted)
  • Stack height: 31.75mm
  • Clamp bolts: 8X1.25mm (X4)
  • Pinch Bolts: 8X1.25MM (X2)
  • MSRP: $59.99 (purple, blood red, black), $74.95 (sweet leaf, camo)
  • Made in U.S.A.
Page Created: 9/25/2018  ----->  Info Updated: N/A
Submitted by pharv85 (View all 378 posts)
  • Posted 9/25/2018
  • Updated 9/25/2018
  • 98 views
