Reference / Information
Odyssey 41 Thermal
Odyssey
Taiwan
1999–2018
https://shop.odysseybmx.com/collections/41-thermal
Odyssey 41-Thermal Heat-Treating Process
  • Odyssey's revolutionary 4130 chromoly heat-treating manufacturing process
  • Secretly formulated in California
  • Introduced by Odyssey in 1999
  • Pioneered, developed, and continuously perfected by Odyssey
  • The process continues to evolve and change, along with the products which proudly carry this famously trademarked name
  • Odyssey constantly strives to make this process better through continuous experimentation and true engineering - their lab and ride testing is methodical
  • 41-Thermal products are backed by years of research and development, and they have always been fully supported by a lifetime warranty
  • The 41-Thermal® process encompasses all stages of production, and includes Odyssey's own joint preparation controls, refined welding techniques (now visible with the larger weld beads), and of course, in the post-weld heat-treatment system that they originally pioneered and continue to refine and tweak to this day
  • Current products (as of 9/24/2018)...
  • Odyssey R32 forks - rust proof black ($144.99) or chrome ($164.99), 32mm traditional offset, 4mm thick dropouts, 3/8" axle slot, 885 grams
  • Odyssey R25 forks - rust proof black ($144.99) or chrome ($164.99), 25mm steep offset, 4mm thick dropouts, 3/8" axle slot, 885 grams
  • Odyssey F25 forks - rust proof black ($154.99), 25mm offset, 4mm thick dropouts, 3/8" axle slot, 990 brake mounts, 912 grams
  • Odyssey F32 forks - rust proof black ($154.99), 32mm traditional offset, 4mm thick dropouts, 3/8" axle slot, 990 brake mounts, 912 grams
  • Odyssey Thunderbolt+ cranks - RHD or LHD, $199.99, traditional bolt-on interface, common lengths (165mm, 170mm, 175mm, 180mm), 22mm Mid BB included, 1lb. 11.8oz.
  • Odyssey Boss bar - rust proof black ($69.99) or chrome ($84.99), Aaron Ross signature, 9.125" rise, 29" wide, 12 deg. backsweep, 2 deg. upsweep
  • Odyssey Highway bar - rust proof black ($69.99) or chrome ($84.99), 9.5" rise, 29" wide, 12 deg. backsweep, 1 deg. upsweep
  • Odyssey Lumberjack XL bar - rust proof black ($64.99), 9" rise, 29" wide, 12 deg. backsweep, 1 deg. upsweep
  • Odyssey Sweepstakes bar - rust proof black ($64.95) or chrome ($74.95), 9" rise, 29" wide, 10.5 deg. backsweep, 4 deg. upsweep
  • Odyssey Thunderbolt cranks - RHD or LHD, $159.99, traditional bolt-on interface, common lengths (170mm, 175mm, 180mm), 1lb. 11.8oz.
  • Fork Testing...
  • Handlebar Testing...
  • Crank Testing...
  • For testing questions, contact Odyssey vis e-mail at stampy@odysseybmx.com
Text from Odyssey Website wrote:
41-THERMAL
Legendary Lifetime Warranty
41-Thermal® is the 4130 chromoly manufacturing process that starts at the design stage, carries on throughout manufacturing, and is only completed when we reach the finishing steps. There are an endless amount of variables to fine tune, and every action along the way counts and matters.
We introduced 41-Thermal in 1999, and the process continues to evolve and change along with the products which proudly carry this famously trademarked name. Other companies have attempted to write the process off as a “gimmick” or they’ll say, “it’s just heat-treating.” The truth however is that nothing has revolutionized the manufacturing of chromoly BMX forks, bars, cranks and frames like 41-Thermal has.
We pioneered it, developed it and continue to perfect it, never at the mercy of feebly asking manufacturers to do “whatever that other company is doing.” Our lab and ride testing is methodical – constantly striving to make the process better through continuous experimentation and true engineering.
41-Thermal products are backed by years of research and development, and they have always been fully supported by a lifetime warranty.
Lab tested. Team Proven.
Source: Odyssey website, 9/24/2018
Website: https://shop.odysseybmx.com/collections/41-thermal
Page Created: 9/24/2018  ----->  Info Updated: N/A
Submitted by pharv85 (View all 397 posts)
  • Posted 9/24/2018
  • Updated 9/24/2018
  • 157 views
