Pages: 1
1993 Bully Piston
#1 2017-12-11 8:42am
- FreeWheelin
- Pro Member
- Bikes: 52
- Offline
1993 Bully Piston
1993 Bully Piston
Cool mid-school bike with a rare Bully Power Fork.
1993 (?) Bully Piston with Bully bars and Bully Power Fork. The brakes are cantilever on front and rear. I was told that the seatpost clamp is an old MCS. The stem looks like an inverted DK, but it is not stamped.
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM.
#2 2020-05-04 6:57pm
- Stingray77
- Centurion Member
- Bikes: 5
- Offline
Re: 1993 Bully Piston
The stem could be a homeless or wilkerson without the sticker? DK made anyway if it is. Had the same frame with caliper brake & a different fork that tapered down past the dropout. Had a built-in seatclamp on it also. That seatclamp is great! What’s the story on the fork?
Wanted-
Cycle-Craft seatclamp, a piece of a wipperman ig8 chain
Oldmidnewskoolbmx
Pages: 1
