2001 Sharp Racing Frame
Sharp
2001–
  • Intended for BMX racing, but plenty strong enough for trails
  • Incorporates oversized tubing with race geometry
  • Material: 4130 chromoly, straight gauge tubing
  • Head tube: 1-1/8" diameter, for threadless forks and clamp-on stems
  • Gussets: N/A
  • Top tube: 0.035" thick tubing, two cable guides at roughly 5 o'clock (bottom right side of top tube)
  • Down tube: 0.049" thick tubing
  • Seat tube:
  • Bottom bracket shell: for American bottom brackets
  • Brake mounts: V-brake mounts
  • Dropouts: 3/8" slot
  • Top tube length: 21" long
  • Chain stay length: 16" long (with axle in center of dropouts)
  • Bottom bracket height: 11-5/8" high
  • Weight: 6 lbs., 1 oz.
  • MSRP: $330.00 to $350.00 USD
  • Made in U.S.A.
  • SNAP Magazine, January 2001, p. 56, "Gearbag" section
Sharp
Sharp Racing Frame
Cost: $330-$350
Colors: Assorted
Info: Don't let the name fool you; this racing frame is built to hold up to its fair share of trails.  It's got a 21" top tube, 16" chainstays, 3/8" slotted dropouts, 11-5/8" bottom bracket height, and is made from 4130 chromoly.  Frame weight is 6 lbs. 1 oz.  It uses oversized tubing with a .049" thick down tube and a .035" thick top tube.
Contact: Sharp * P.O. Box 511 * Lincoln, CA 95648 * Internet: wwwsharpsprockets.com
Source: SNAP Magazine, January 2001, p. 56, "Gearbag" section
Page Created: 9/1/2017  ----->  Info Updated: N/A
  • Posted 9/1/2017
  • Updated 9/1/2017
  • 90 views
