2017 GypsyBikes TrailGypsy
Other
Taiwan
2017
  • Intended for BMX dirt jumping (i.e., trails)
  • Designed my "Midget" Cory Walters
  • Production frames available in two sizes (i.e., top tube length), both for 20" BMX wheels
  • The most reasonably priced after market BMX frame available by an American company
  • Pre orders started on Monday, June 12, 2017 (6/12/2017)
  • The first order of frames shipped at the end of July 2017 (approx.) and were delivered on the first week of August 2017 (approx.)
  • The initial batch of TrailGypsy frames consisted of thirty-five (35) 20.75" frames and thirty five (35) 21.25" frames
  • The first batch of 2017 GypsyBikes frames also included thirty (30) StreetGypsy frames
  • If preferred with a different length top tube, you could pre-order a TrailGypsy frame with any sized top tube length, but it wouldn't ship until after the first batch of frames sold
  • Manufactured by Link Bicycle Co., Ltd. in either Taiwan (Puxin Township, Changhua County) or China (Kunshan City, Jiangsu Province)
  • Material: 4130 chromoly
  • Finish: raw with clear coat
  • Head tube: Integrated, Campy spec (45°/45°), 120mm (4.72") long
  • Gyro tabs: removable
  • Gussets: top tube and down tube
  • Top tube: straight gauge, 31.8mm (1.252") OD, 1.2mm (0.047") thick
  • Down tube: double butted, 34.9mm (1.374") OD, 1.5mm (0.059") thick on ends and 1.2mm thick in middle
  • Cable guides: welded on bottom of top tube, at 6 o'clock
  • Bottom bracket: Mid, 46mm (1.811") OD, 41.25mm (1.624") ID, 73mm (2.874") wide
  • Seat tube: 28.6mm (1.126") OD, 1.4mm (0.055") thick
  • Seat post size: 25.4mm (1")
  • Seat post clamp size: N/A (seat clamp built into frame)
  • Chain stays: 19mm (0.748") OD, 1.2mm thick
  • Seat stays: 19mm OD, 1.2mm thick
  • Chain stay width at 235mm from center of slammed axle: 72mm (2.835") - will probably accommodate up to 20x2.4" rear tire
  • Chain tensioners: built into frame, M4 thread
  • Dropout slot size: 14mm tall
  • Dropout width: 7mm (0.276") thick
  • Dropout spacing: 110mm, for BMX hubs
  • Top tube length (TT): 20.75", 21.25"
  • Head tube angle: 74.5°
  • Chain stay length: 355mm (13.98") slammed
  • Bottom bracket height: 40mm (1.575") above the horizontal axle-to-axle line
  • Stand over height:
  • Seat tube angle: 71°
  • Dropout slot length:
  • Wheel base: 933mm (36.73") with a slammed rear tire and a fork with a 35mm (1.378") offset
  • MSRP: $150.00 USD + $20.00 USD for s/h (or free pickup at the GypsyRanch in Stonyford, CA)
  • For purchasing, make money orders out to GypsyBikes and mail to 1861 Fouts Springs Rd., P.O. BOX 243, Stonyford, CA 95979
  • Forks and bars (sold together) are expected to be available for purchase sometime later in 2017 for $100.00 USD + s/h
  • Made in either Taiwan or China
Page Created: 6/19/2017  ----->  Info Updated: 6/21/2017
  • Posted 6/19/2017
  • Updated 6/21/2017
  • 257 views
