Reference / Bottom Brackets
Profile Euro V2
Profile Racing
2016
http://www.profileracing.com/
Profile Racing European V2 Bottom Bracket
  • Designed for frames with European (Euro) bottom bracket shells
  • Compatible with cranks that have a 19mm (3/4") diameter spindle
  • Available sometime after 2005 through 2016
  • Allows for the narrowest Q-Factor (distance between the pedals)
  • Gives you the ability to set up your chainline as close to the centerline of the bicycle as possible
  • Kit includes: threaded cups (2), bearings (4), tube spacer (1), cone spacers (2), & aluminum spacers
  • Cups: left-hand (LH) & right-hand (RH) threaded cups - see installation advice below
  • Material: CNC machined aluminum cups and cones
  • Bearings: precision sealed, self-lubed
  • Axle size: 19mm
  • Bottom bracket widths: 68mm (most common), 73mm, 83mm, and 100mm
  • Colors (cups and cone spacers): silver, black
  • Weight: 5 oz. (155g)
  • Installs with either Park BBT-9 or Shimano TL-FC32 tools
  • MSRP: 39.99 USD (Profile's price in 2016)
  • Sold at Dan's Comp for $34.95 USD (in 2016)
  • Made in the U.S.A.
Note that the cup with the ring machined into its exterior shell is the right-side (drive-side) cup.  This bearing-cup assembly will thread counter-clockwise into your frame.  The other cup is for the left-side (non-drive side) of your frame.  This second side cup threads clockwise into your frame.  This is extremely important to understand before you try to install your bottom bracket!
Here are a few informative pages/videos that will help you install your Euro bottom bracket cups and the correct size tube spacer:
Also note that the tube spacer goes in between the bearings, like a sleeve over the axle, which prevents the bearings from being smashed into the frame when you tighten the crank arms.  If the tube spacer is too short, even by just a few millimeters, then it's not doing its job. People will say, "I tightened my cranks down and now they won't spin freely."  That means the tube spacer is too short.  If the tube spacer is too long, the bearings will not seat all the way into the frame.  Normally a 48mm tube spacer is used with 68mm BB shell and a 53mm tube spacer is used with a 73mm shell.
Page Created: 3/19/2016  ----->  Info Updated: N/A
  • Posted 3/19/2016
  • Updated 3/21/2016
  • 225 views
