BMX Bikes / G / General Bicycles / 1987 General Osborn Pro
it is A 1987 RL OSBORN PRO frame. that I built up as a Genral dayly flattland ride. OLD SCHOOL(OS) meets MID SCHOOL (MS) build.  so it is not stock. the former owner cut off the rear weld on foot pegs . to put on better pegs it has (MS) NOS Odyssey T bars Zero sweep for flatland. DIA-COMPE Tech 77 (MS) levers no lock butun. (MS) BIG CHEESE grips.  (OS) GT meat malet stem.ODYSSEY gyro with (MS) ODYSSEY cabel narps to make it work on my frame. the narps let you custom size the gyro cabels to fit.  (MS) ODYSSEY slike cabel up frunt. (OS) TIOGA BEAR TRAP head set.  (MS) KORE ZERO offset forks grate for flat land. (OS)  PERGRINE HP 48's with suntor coaster brake freewheel .(MS) PRIMO TUBE STAKE alloy pegs. (MS) primo v monster tires. (MS) primo hemroad seat.  (MS) PRIMO rode micro ajust seat post. (MS) GT dubbel bolt seat clamp. (OS) ACS small post BRAKE (MS) had biger  post. (OS) DIA-COMPE  990 AD brake in back. (OS) SURGINO 150 MM 1PC cranks. (OS) SHIMANO PDMX pedals. (MS) MONGOOSE bottom bracket. (OS) sprocket from a SCHWINN 1970 PIXY. All I need now is to find the Decals!
Submitted by FRESSTYLE FREEK
